'22 King Ranch - brake squeeling
Air00Max
Cincinnati,OH
My wife's '22 King Ranch has had some rear brake squealing going on the last couple of weeks (just hit 5K miles). I took it into the dealership and the tech noted that he could "feel something going on" with the back brakes, but mechanically pads/rotors/calipers checked out. Dealership then offered a brake service for $180. WTF. Anyone else experienced any brake issues so quickly on their Expedition? If so, what was the issue/resolution?
Thanks!
99WhiteC5Coupe
Thanks!
I have not experienced a similar situation as you - but your brake issues should be covered under the new-car warranty. Read your warranty folder.
Certain items (brakes, wiper blades, etc.) have a shorter warranty that the 3-year / 36,000 new-car warranty.
What did the dealer propose to do for a $180 brake service?
What Ford dealer are you dealing with? I live in Butler County, but go to a Ford dealer in Hamilton County.
2020FordRaptor
Nevada
Thanks!
Why would they charge you for that? It should be under part warranty since they shouldn't go out that fast.
A
Air00Max
Cincinnati,OH
For the $180 they proposed a brake and caliper service to "clean up the slides and pins." This was at Beechmont Ford, which is closest to me. I typically drive out to Lebanon Ford but Beechmont was able to get me in quicker.
maxlim2022
Illinois
mine are squealing mildly as well particularly when braking from a slow speed. Ill just continue to watch and see...I do not know that squeaking brakes - unless hideously loud and defective, would be a warranty issue.
CDNRabbit
Ontario Canada
Mine squeals alot. Started in the back but now sounds like all four corners. Planning to talk to dealership when I go in to change oil before winter. I also inspected the brakes on the lift last week and saw nothing that would cause squealing. Guessing it's the combination of pad and rotors.
VikingRaider
Chicago
Very frustrating— I have the same issue. I've taken it to two different dealerships a total of 3 times. First time, I was told there was nothing wrong, and when I insisted they take a closer look, they found the right rear break pad hadn't been fully seated at the factory and "fixed it". For the next three days, it worked flawlessly, blissfully silent brakes. Then over the that weekend they started quietly squeaking, only at low speeds. The following week they were full volume squealing like an old rusted school bus. I took it back to the dealer (same I bought from) and they looked it over again and said there's nothing wrong, the brakes are in great shape — good job me for not slamming the breaks by the way (6000 miles) — and they can't replicate the sound. I took the truck out into the parking lot and recorded the sound, then brought it back and played them the videos on my phone. Then the senior guy pulled me aside and said look, it's an issue people see on F-150s and Expeditions. Basically there's nothing wrong safety-wise, it just makes noise. If we switch out for softer pads or harder pads, it will stop the sound, but it's not going to change much. He said if it's still doing it after 500-1000 miles to come back. What they'll do then, other than tell me it's fine, he couldn't say.
Last week I had a flat tire on the way to visit my mother-in-law some hour and a half from home. Luckily, she's on great terms with the local Ford dealer and got me in to the service department (small town, everyone is family) as soon as I limped into town. I asked THAT guy the same question about the brakes and he said it's because Ford shifted to poly-alloy parts. The aluminum in the parts is mixed with other metals and they rub differently and wear differently and corrode differently than the old style brakes of years past. With a vehicle as big as the Expy-Max, it's going to be loud and there's nothing anyone can do short of switching out brakes for aftermarket ones which he didn't recommend. He said it's all in the name of getting the almighty EPA ratings...lower weight means better gas mileage. Welcome to the future and embrace the suck.
F that. I paid $80,000 for a car that squeals like a twenty year old Pinto getting dry-reamed by a Dodge? Screw the EPA and gas milage, these brakes are like fingers on a chalkboard EVERY SINGLE TIME I slow down.
But luckily, "there's nothing wrong."
(I will note that outside the brake issue, I absolutely LOVE this vehicle and there's nothing else I can complain about. At all.)
Tuebor
Detroit
Just noticed squealing rear brakes on my '22 Timberline a few days ago. 4900 miles. Thanks for letting me know it probably wasn't my imagination.
mlogan
Stillwater, MN
Just noticed today at about 8k. I’ll keep an eye on it. Some pads do that (had a bmw that regularly made some noise) but seems odd on a Ford.
KetMalice
Oklahoma
My brakes are squeaking very badly, 22 Timberline with 11k miles. It’s the rears too, I haven’t taken it in yet.
JakeInTexas
Mansfield
22 timberline with 16k-- squeaking in the mornings only, forward and reverse. After getting out of the neighborhood there is no noise. I'm pretty hard on my breaks though, catch my self enjoying the throttle and power then next thing I know, the brakes are getting worked. If I keep it long enough, Wilwood brake kit with orange matching calipers would look and feel sweet.
lurch
Boulder, CO
Has anyone found a fix for this? My brakes were quiet until my 3rd set of brakes. They started squealing badly 6 months after I had them installed. Brakes Plus claimed the rotors had overheated and the pads glazed, so I replaced everything again. The 4th set lasted 3 months before squealing started.
Fastcar
Army
FL
Thanks!
I had a rear brake issue on our 2021 and it turned out to be the keep in your lane deal. It was screwed up and was applying the rear brakes constantly.
