Todd40
DRIVER AND PASSENGER WINDOWS ROLL UP SUPER SUPER SLOW EVEN AFTER I HAVE TREATED BY SPRAYING A TYPE OF GREASER TO COMBAT THE VELVET RESISTANCE. DO WE NEED NEW MOTORS?
How can I tell if it is the regulator or the motor. Can the motor be tested?Replace the window regulator. They are a door-sized unit that consists of pulleys and nylon lines that pull the window up and down. They get gummed up, and if you are patient can bec leaned up to remove the solidified grease and operate well again. The motor's fine.
It isn't the motor. Like Trainmaster said, it's the regulator. There are cables ( like bicycle shifter/brake lines ). They can get gummed up or crusty. I tried dripping tri-Flo oil in the sheaths, but it didn't help in my situation. I just ordered a new regulator like I should have in the first placeHow can I tell if it is the regulator or the motor. Can the motor be tested?
