Fastlane429
5.4. Had a plugged left converter. Also replaced plugs and coils. Hooked up to my scanner. My issue is barametric pressure. Reading 13.5 psi and 126Hz. Hooked it up to my 05 mountaineer and 08 F250 on both read 14.5 and 156Hz. That is right for my area. 13.5 is supposed to be for 5,000 feet or higher.
I need to know where it reads barametric pressure in this system. There is no MAP sensor it doesn't get it from the mass air flow sensor either. With this reading it makes it run way lean which is why and burned the plugs up and plugged the converter.
