ExplorerTom
I did a google search and found several posts talking about it. No official word from Ford that I saw in my 2.5 minutes of looking.
Ford acknowledged they have a problem with the plastic pans leaking and they are replacing them all with aluminum pans if your plastic one leaks. I'm not sure how much clearer this KNOWN issue can be. There's no hidden secret or something here, just facts from FORD themselves. My dealer fully expects to replace mine as they've replaced many on their other vehicles recently.....
So a single ford service manager admitted a problem?!?! But regardless, even if there is, that is not saying the material is at fault. It could absolutely be a manufacturing defect. All I am saying is people are acting like it is just regular old plastic. It is not! The plastics and composite materials used in today’s vehicles is probably more advanced than most of the metals being used. There are manufacturers experimenting with composite engine blocks.
It’s been a problem. They were using plastic oil pans on F-150s with V6 engines until February 2018, then they quietly switched back to metal. So it’s based on when your F-150 was built, not model year. At least for Raptors. My 2017 Raptor has a plastic oil pan and drain plug. My 2018 Expedition is metal.
Lots of guys reported leaks on the Raptor forum the last couple years. But my understanding is if it leaks, they don’t replace it with metal. If you had plastic going in, you get it back with plastic.
there has never been a recall on a metal partFord had a recall on plastic intake manifolds cracking. The Ford moto seems to be, put out a inferior product and fix it later. I don't see any weight or money savings either. My 2000 has a stamped metal one and looks brand new.
Any gun people on the forum? What two guns do you see the most pictures of "blown up" at the range? Glocks and AR15s. I know there are a lot of them out there but they are also plastic and aluminum. Light, cheap, easy to produce and not quite as durable as heavier, harder, more expensive steel.
The upgraded crossover tube on the plastic intakes, are now aluminum.there has never been a recall on a metal part
yep, there has NEVER been a recall on anything metal!!! LOLThe upgraded crossover tube on the plastic intakes, are now aluminum.
Gaskets do fail, no question about it. The metal pans I’ve seen in the past that leaked were, more often than not, over torqued causing the pan around the bolt holes to warp which lead to premature leaks..... easy fix. I wonder how the plastic fairs to over torque, I’d assume cracking. I’m not concerned about the plastic vs metal debate. I’ll be placing skid plates on mine and never think about it again.We all know that if you have metal pans on the engine and transmission they will never leak or break. I just wish someone would have told all my oil pans and transmission pans that...my experience has been that anywhere there is a gasket its going to leak at some point and anything on the bottom of the car is bound to get a hole punched in it if you drive offroad long enough. I have skid plates on my metal pans too cause for some reason they get holes punched in them. I guess they just make crappy metal now days too? But then I remember even the old "real" metal pans leaked and got damaged.
