Eric
The Ford owners manual and the oil cap indicate using 5W-20 synthetic blend oil in the 5.4 Triton 3V. I was wondering if anyone out there has done any testing with 5W-30 full synthetic?
The reason I ask is that Costco regularly offers a $10 off coupon for 6 quarts of Mobil I 5W-30 oil and it's a hard deal not to pass up. My understanding behind the 5W-20 recommendation relates to the higher flow rate and thinner viscocity which allows slightly better fuel economy. As for protective qualities one would think the full synthetic would be better than the blend (as long as it's changed within the recommended mileage intervals) and that the difference between the 20/30 weight would be more of a heat issue, in other words if you live in a hot climate vs. cold climate.
Just wondering if there is a risk in using the 5W-30 Mobil I.
