I am looking for some guidance on where to focus my efforts to address an electrical short that drains my new battery.
Here are my data points on my electrical short.
- once the truck is jump started, the alternator is charging the battery fast enough to restart on its own with less than 5-minutes of run time. Volt meter shows >14V while running but did occasionally drop to ~13.1V for a seconds before recovering.
- the instrument cluster back/needle lighting has a faint glow with the interior lighting control wheel turned all the way down, and clicked into the off position.
- aftermarket GPS stereo head unit was flickering between daytime illumination and nighttime illumination when lights were on, but now remains in the nightime illumination mode even with the headlights off.
- the day before the issue started, a mechanic replaced the rack & pinion, lower steering-shaft, and all tie rod ends. I can't figure out what electrical and circuits would have been impacted by the steering work accept for the TPMS.
If hanks in advance for any ideas/guidance to find the root cause!
