97 EB w/ Air Suspension, checking ride height
AuctionExp
Beaverton, OR
97 EB w/ Air Suspension. The compressor has been coming on w/ more frequency and the 'check suspension' light illuminates from time to time.
Does anyone have the stock ride height or distance measured between the top of the tires and the wheel well clearance?
Also, outside of stock replacement parts, does anyone know of an aftermarket company that makes air suspension replacement parts that will fit w/out modification?
Thanks.
TexasAngel34
Peyton, CO
oh yes def do the swap for the coils... my air ride is a pain and i plan on doing the swap very soon...
Experdition
arkansas
reefkrazy
ct
Your truck looks like it is lifted. What did you use , considering that you are still on the sir suspension, right?
Three inch body lift. torsion bar twist. I also took the air ride sensors and adjusted them to go higher. If you look under my post I did a write up on how to adjust the sensors.
