Fairmont302
1998 expy, 5.4. 4x4 150k miles.
the truck has been sitting for 4 months i believe. i went to start is and it ran for just about a min. then just puttered and died.
i check fuel pressure, 41psi koeo, held 41psi koec for a few seconds then came down to 38psi.... that still should have starting capacity.
pulled a coil and put a plug in it, it has spark.
led noid on the injector, its pulsing.
starts with starting fluid (knocks bad on it,
so here i am, scatching my head... truck message center says 158 miles to empty, gauge shows maybe half tank. did someone steal my fuel and replace it with water? did i get super bad fuel and it went oober bad over winter? when i started the truck is seemed to run long enough to empty the fuel lines and filter?
please help
)so here i am, scatching my head... truck message center says 158 miles to empty, gauge shows maybe half tank. did someone steal my fuel and replace it with water? did i get super bad fuel and it went oober bad over winter? when i started the truck is seemed to run long enough to empty the fuel lines and filter?
please help
