smonroe86
So today I opened the vent window, when I went to close it nothing happened. So I'm assuming that's it for the motor. When can I find this motor online? I'm not having much luck.
Thanks
Thanks
before you replace the motor make sure the switch is operating correctly. Reason for this is if the motor opened but wont close could be due to a faulty switch the motor works by receiving a voltage that is reversed by the switch . One way to test this would be to take the passenger side switch and install it in the drivers side that is if the passenger side is working If you need a copy of the wiring print let me know
