macleod409
Hi, first off thanks in advance for any advice any one can offer me on this. I have been searching your site all day and have not found the answer. Its probably there, I am just bad a finding things.
I have a 99 Expedition that has ran great since we bought it brand new in 98. It has just over 100k on it. Recently it started giving us trouble. It started with it not starting. You would turn the key and hear one click from the starter solenoid but nothing after that. If you tried over and over by turning the key on and off, it would finally start. First it was only a few tries and it started. After a few days it was down to twenty tries before it would turn over. But once it did, it fired right up and ran normal until the next time it was shut off. I replaced the solenoid on the fire wall and it changed nothing. I replaced the starter and it fired right up. Then I shut it off and went to get the wife to show her my proud work and it did it again. Finally it started and that starter would not disengage. You could here it going a million miles an hour, a very loud wine noise. You could also smell something burning, but I don't know what, it was electrical. Maybe the alternator went out? All of a sudden it stopped and every thing was fine. I took the car around the block to see what was going on. About half way around the block the dash shut off and the windows would not roll down. It was dead on power but running just fine. I took it straight home and shut it off in the drive way. I cant get it to start at all now. I notice the battery is not charged now, so its not getting any thing from the alternator? If you turn the key on and off, about every fourth or fifth turn the locks go up and down on all the doors and the gauges go full on to full off. It very weird.
I put a screw driver across the solenoid today and it does nothing. I am lost as to what to do next. I refuse to take it in, I am a do it yourself-er. Is it the starter? Did I get a bad one? It was not to hard to put in and take out, but not my fav job to do.
