99 Right Rear all the way up
turbokev
NH
EDITED: LEFT rear is up.. drivers side.
My 99 had the CHK SUSP light come on a few days ago..
I notice that the drivers side rear seems to be lifted all the way (or most of the way)
With the truck on level ground, that corner is 2.5 inches higher than the passenger side.
I put a bunch of weight on the passenger side and the compressor turn on and levels that side.. then when the weight is out it returns to normal..
Drivers side does nothing..
The code it throws is "LR out of range" maybe indicating the sensor on that side has failed?
Is the sensor replace-able? or is the sensor internal to the whole assembly?
Other than this issue, the air ride has been perfect in this truck.
Thanks,
