A/C Sporadic Issue
Nate03
Ohio
I have a 2017 XLT and lately the AC will blow warm air if after a short drive if I turn the car off and turn it back on. Like today I stopped at a carryout restaurant. Came back out and turned the car back on and it started blowing warm air and wouldn't cool down. Doesn't matter if I manually change it to max AC or any setting. I stopped after a while and turned off the car and started it again and voila it started blowing cold air. Any ideas? I have the big screen and auto zone controls too.
bobmbx
Whats the ambient temperature?
762mm
Quebec, Canada
If issue is intermittent, check your electric fans. One of them may have an issue.
This is a good video about AC issues:
stamp11127
Temple, Georgia
Lazy ac relay if used
Low pressure switch is on its way out
Electrical issues in the ac control circuit
Compressor clutch may be on the way out
Alternator or battery is failing - pcm disconnects unnecessary items to limp home
Won't know what the problem is until it is diagnosed correctly. Start with a multimeter for the electric.
stamp11127
Temple, Georgia
