A few leveling questions
LastExpo2000
Corpus Christi, TX
panda24619
San Diego
so what do you have now? air? then convert it first with this. crank your t bars and add a 2" spacer. itll level it, if its already lifted then just see if you can crank anymore and get a 3" spacer. then you can fit 305s no problem, but you can even fit 315s.
LastExpo2000
LastExpo2000
Corpus Christi, TX
Would 305s fit with a 2" rear spacer? What about wheel spacers?
panda24619
San Diego
youll fit no problem. on stock rims!!! other wise you can get 8" wide with a 4.5" backspacing. any wider or different backspacing youll rub somewhere. and need to trim or get wheel spacers. so no need for wheel spacers and you can fit 305s. itll be about 33-34 depending on the tire. 315s are about 34-35. remember that 305 is the width and the next number is the percentage of the width on the sidewall and 3rd number is the rim. use this so you dont get confused. http://www.redrock4x4.com/tireconve...txtWidth=&stxtRim=&submitButtonName=Calculate
LastExpo2000
LastExpo2000
Corpus Christi, TX
Okay thanks, I was going to add spacers only to give my expy a wider look. That wont put too much wear on my front and rear end will it? Im going to stick with my stock rims for now
panda24619
San Diego
it shouldnt. i mean anything will, but if your going to do spacers dont go off any big jumps! haha but also you might have some rubbing issues. you will if you do 315s, but with 305s you might have to trim the plastic pieces a little bit. not much.
walnuts4x4
Watertown, NY
hell... I'm running a 10" wide rim and a 1/4" spacer up front with 37s and no problems at all... and mudryder has bigger spacers and 38s with no problems
panda24619
San Diego
BACKSPACING!!!!!! thats where it comes down to for the rubbing.
walnuts4x4
Watertown, NY
shouldn't be a problem... just make sure they are good spacers and you are going to need to re-torque them every so often... like check the torque with every oil change... also I would look for "hub-centric" spacers too if your gonna use 1" or bigger
LastExpo2000
LastExpo2000
Corpus Christi, TX
Would it be a good idea to use some lock tight on the studs before I torque them? I should be able to fit 305s right? I just want to make sure and would that be a tight fit? I'm keeping stock size rims
walnuts4x4
Watertown, NY
wouldn't hurt to put the lock tight on the studs that hold the spacer on... but not on the studs that hold the rim on........:badidea: but biggest thing with bigger spacers is keep an eye on the torque... if you do you wont have any problems... just like when you get new lug nuts your supposed to retorque them too... but spacers I would take the extra few min to be safe.... just my .02
LastExpo2000
LastExpo2000
Corpus Christi, TX
No worries I'll keep an eye on them. But would 305s be too much? This is with a 2" leveling kit in the back. How much space will I have left in my wheel wells between the tires and top of fender
walnuts4x4
Watertown, NY
i really dont know that one... mine went from stock to 37s.... maybe someone else can chime in...
LastExpo2000
LastExpo2000
Corpus Christi, TX
I'm having trouble finding 1.25 or 1.50 spacers. What is the stud size on a 2000 expedition? What type of spacer am I looking for exactly I know hub centric but brand and measurement wise?
DR3W
L.A. - IE/SoCal
Well how big are your tires now? 30' tall?
Because in metric tires it is this:
Say your tire is P-305/60/R-17
P ......is tire type (P-passenger/T-temporary/C-commercial)
305... is section width of the tire (in millimeters)
60 ....is aspect ratio [(section height) divided by (section width)]
R ......is construction type (R-radial/B-bias belted/D-diagonal(bias))
17.... is rim daimeter (in inches)
Thats what all that means for metric ratings. Hope this helped.
Remo
Hartford, CT
Remo
Hartford, CT
