ABS Light On - Codes read 1095 and 1235
Cre8ive1
SoCal
ABS Light On - Codes read C1095 and C1230
My light has been on for a while and now I'm selling the car but want to fix the ABS first.
Here's what I know/ have done:
Cleared the codes and they came back.
1) Measured resistance of Front and Rear sensors at the sensor connectors and at the control module connector.
Left= 2.5K ohms
Right = 2.4K ohms
Rear = 1.9K ohms
I replaced the rear connector just in case...
I replaced the Brake Position Switch just in case
2) I've spun the front wheels and the resistance change.
3) I have 12V on pins 9 + 25 at the module connector
4) I have ground on pins 8 + 24 at the module connector
5) I have 12V and ground at the connector going to the pump motor
6) I applied 12V from a battery charger to the motor connector and the pump motor works.
(5 + 6 with the pump motor connector disconnected from the module)
7) Brakes are a little 'spongy' with the car running, but pump up harder when it's not running.
I'm going to bleed the brakes this morning and see if that makes a difference. The only other thing I can think of is the the 12v output from the module is not supplying enough current to drive the pump motor and I need to replace the module.
Any help/ ideas would be greatly appreciated.
Thanks,
Kevin
Bedrck47
Elizebethtown, PA
Sensor
Connect EEC-IV 60-Pin Breakout Box to the EHCU with ABS Adapter Cable.
Disconnect the suspect anti-lock brake sensor.
Check the harness for short to ground.
NOTE: Use 88 Digital Multimeter with the minimum resistance hold feature enabled for this test.
Monitor the resistance between EEC-IV 60-Pin Breakout Box pins and ground as follows:
Sensor Breakout Box Pins Circuits
Left front anti-lock brake sensor 12 and 4 521 (TN/OG) and 522 (TN/BK)
Right front anti-lock brake sensor 13 and 5 514 (YE/RD) and 516 (YE/BK)
Rear anti-lock brake sensor 14 and 6 523 (RD/PK) and 519 (LG/BK)
Drive over rough roads at various speeds.
If there is continuity between either circuit and ground, repair the circuit for a short to ground.
Check harness for open circuit.
NOTE: Connect jumper securely to the suspect sensor connector.
Connect a jumper between the two pins on the suspect sensor connector.
NOTE: Use 88 Digital Multimeter with the maximum resistance hold feature enabled for this test.
Monitor the resistance between EEC-IV 60-Pin Breakout Box pins as follows:
If there is open circuit detected between pins, repair the circuit(s) for an open circuit.
Check suspect sensor electrical connector.
Monitor the resistance between suspect anti-lock brake sensor terminals while wiggling the electrical connector:
Sensor Resistance
Front
4x2 4000 ohms
4x4 500 ohms
Rear
4x2 or 4x4 3500 ohms
If the resistance is above specifications, install a new anti-lock brake sensor.
Monitor the resistance between suspect anti-lock brake sensor pins (component side) while wiggling the electrical connector:
Sensor Resistance
Front
4x2 2000 ohms
4x4 300 ohms
Rear
4x2 or 4x4 800 ohms
If the resistance is below specifications, install a new anti-lock brake sensor.
Monitor the resistance between an anti-lock brake sensor pin (component side) and ground on the highest resistance scale of the meter, while wiggling the electrical connector.
If the meter shows anything but open circuit, install a new anti-lock brake sensor.
No members online now.
Landsbutter
