AC Evap core drain on 05 Expy
B
bivenspack
Seaside, CA
Now that we've been using the AC I've got water in the passenger side footwell. I think the drain may be clogged, where does in come out under the vehicle. I know it's somewhere at the front of the tranny tunnel but I can't see it. Any help?
toms89
technical advisor
MD
Here it is a little to the left from the center of the photo on the firewall in a 1st gen expy. May be similar location in 2nd generation??
Pretty much behind passenger side head next to tranny bell housing.
bigcrunch
Ga
On my 2006 with mid row captain seats one of the inner arm rests has come loose allowing it to rotate past the stop, I have an idea it maybe bolt loose on the inside??
Or how is it tightend? accessed?
thanks,,,,,,,,,,,,,,,
sgtowing
Supporting Members
Valrico, Fl
You have to STREEEEEEEEEETCH the leather over the joint to access the bolt. I was to scared so I took mine to an upholstrey shop.
bigcrunch
Ga
I pulled the leather off the arm rest dont see the bolt head, from the inside?
sgtowing
Supporting Members
Valrico, Fl
It is recessed inti the padding. You'll have to peel some back.
Sent from my DROID BIONIC using Tapatalk
bigcrunch
Ga
I pulled the leather and foam back, no bolt head.
What is it supposed to look like??
