AC issues & Drive Mode Unavilable
DontLoveItYet
Oklahoma
Just purchased a 2019 Expedition with 8K miles. One day later I ran the AC and it wouldn't blow cold air. After driving with AC on for about 30 miles it suddenly began cooling. The following day, same thing. Didn't blow cold at first, but finally switched over to blowing cold air.
Day 4 of Ford ownership--made a 2.5 hour drive. Didn't even try the AC as weather was cool. On the way home, switched AC on and it cooled right away. 1.5 hours into the drive back (with cruise control on and AC working) vehicle suddenly cut out and cruise control went off. Dash showed "Drive Mode Unavailable". Pulled over to the side. Gauges looked fine, other than it showed a little wrench. I was about 20 miles from a dealership so I proceeded to go there. Could not switch Drive Modes. Could not use Cruise control. Engine would cut out, losing power 2 more times on the 20 miles to the dealer.
Now dealer can't get my fairly new Expedition to show any codes. They said I'll just have to drive it and have it towed in the next time it has an issue.
Not sure if the two issues are related. Anyone have experience with this?
armoredsaint
Ohio
I have some electrical gremlins too, it's annoying as hell.
Go to another dealer, lots of them are dumber than a box of rocks
wakeboarder
Fort Lauderdale, FL
The only time I received the “drive mode unavailable” was after programming with Forscan. A little bit of driving would reset it. Programming with Forscan causes modules to reset. Maybe one of the modules has an intermittent connection or isn’t working correctly causing a rest. I’m not sure if Forscan can tell on the fly if a module is acting up. I honestly have very little knowledge of this.
Dice Roll
Craps Table
Drive modes is one of the things controlled by a module on the number 36 fuse. Mine was blown by aftermarket dvd installation. Still trying to get that straight.
spiderman865
Chicago Area
Long story short, I have had "drive mode unavailable" intermittently since the day a purchased my 2019 Platinum brand new w/22 miles. Been back to the dealer several times. They pull the codes, replaced a module, that didn't work. Thought it was a harness getting wet so the rigged up a oil bottle to cover the harness, not dice. Still happening. Now I am working with Ford on a replacement vehicle. Love the truck when I am able to drive while not at the dealer, but something is not right and no one is able to figure this out.
99Redcobra
MA
What was the final outcome? Did you get a replacement vehicle?
D
DontLoveItYet
Oklahoma
I finally took it to a dealer that wouldn’t quit searching for the issue. They ended up speaking to Ford engineers and were advised to reprogram the drive train. The Ford engineers said they’d only seen this issue one other time. We are now 5000 miles after the reprogram, and it has not had any further problem. (Knock on wood!!) My AC issue was a separate problem.
spiderman865
Chicago Area
Next Saturday I am swapping out my 2019 for a 2020.
Today was the day. Swapped the 2019 for the 2020. So far couldn’t be happier how the whole process worked even though Ford dragged their feet and I had to stay on top of them. They really want to discourage you by dragging out the process.
Shaffer9
Ms
What was the AC issue attributed to?
Laura M
Orange County. CA
Almost done with our Navigator lease. I've been ignoring the right side mirror moving/clicking continuously @ starting the engine, BUT the drive mode unavailable box flashes when I need it. I've been trying to use 'conserve' due to the price of gas (ha) and until a few weeks ago it would change into that mode. ....but it wasn't funny when I drove in icy snow in the local LA mountains a week ago and could not put it into 4X4! No slow climb NO slippery roads! Could not use it to get up into our lake arrowhead driveway. Kinda the best feature on the car (for me). a year ago when it worked, it drove cleanly past slipping cars in deep snow in Twin Peaks. I hit the hood (yeah, I'm a girl), wiggled the knob, vacuumed out the parking brake, and started the engine with the remote, which actually MADE the mode work! It goes into 4x4 every 7th time I start the engine, but 20/22 times it won't go beyond that. Once it stayed in slippery and once it stayed in deep conditions. guess I'm far too demanding to expect a $100K vehicle to function. Not thrilled to gamble on starting the engine on the side of a snowy road 48 times in hopes it will move into a safe drive mode. Ideas?
Motorcity muscle
Motorcity
Would start your own thread for this issue.
No members online now.
rockinghranch
