Ac not cold and sporadic airflow
RC Walter
Orange County
2019 Exp. wiht 48K miles.
On hotter days ac will not blow cold and the fan will not blow air or blow at a reduced speed (even on high) out the center vents.
Dealer is saying:
A/C pressure low at 60 psi. Traced A/C systtme and found refrigerant leak from Rear A/C evaporator assembly. Need to replace rear evaporator assembly and retest.
COST: $2,303
(OucH)!!!
rd618
new york
Dealer is saying:
COST: $2,303
(OucH)!!!
sounds like you don't have extended warrantee, in that case get a second quote from a local mechanic who can do the refrigerant.
especially work like that, pricing can be hundreds less.
sharprd65
