AC pressure switch/No voltage
joe gregor
Ohio
I replaced the condenser on my 04 Expedition, pulled a vacuum and tried jumping the pressure switch connector so I could start adding Freon. Compressor never kicked on with jumper and found no voltage while checking with a meter at connector. Any clues?
J
joe gregor
Ohio
2004 Ford Expedition XLT 4x4/ Manual controls
The truck was in a accident and the core support was rotted out. I replaced the front core support, grill, hood and ac condenser. When I tried jumping the pressure switch to add Freon the compressor would not kick on, no voltage at compressor or switch.
Temple, Georgia
First 5 of 7
  • 55-1.pdf
  • 55-2.pdf
  • 55-3.pdf
  • 55-4.pdf
  • 55-5.pdf
J
joe gregor
Ohio
I appreciate this. I will try trouble shooting again this week after work and let you know how it goes. Thanks again for your time.
Temple, Georgia
Probably would be easier if I had given you the correct diagrams. These are for the manual system.
  • 54-1.pdf
  • 54-2.pdf
  • 54-3.pdf
  • 54-4.pdf
grey169
wisconsin
FYI I had replaced my compressor (locked up) and I did a few hours of troubleshooting. I should have listened to someone who had told me to check the FUSES. Mine is running like a champ now.
Junker
