Accessory ports not working
EMTPJ
Utah
Ok, so my son was playing around with my phone charger and now it doesn't work. I thought at first it was the charger itself, but it works in my other vehicles. This leads me to think it is the the charging/accessory ports in the Expy. I tried the port on the dash, as well as the one on the back of the center console, and neither work. I tried other chargers in these ports that are known to work, and they dont work in the Expy now. So this really makes me think that it is something with the charging ports in the Expy. They both worked before he started screwing around... grrr...
So I am thinking that since both are not working now, perhaps it is a fuse. Any ideas where to look? I am a bit of a noob, so be kind please.
Patrick
B
bedrck46
It helps to know which year the expy is due to changes in wiring diagrams But also suggest you check your owners manual to find out which fuse controls what. If you don't have a owners manual you can download one from the following
owner.ford.com
B
bedrck46
Power distribution box in engine compartment
check fuses #65 and #66 20A fuse #71 and #72 20A fuse check with a meter
B
bedrck46
check the fuses those are what controls power to the power ports
