Active suspension bypass 2020
Bwiddie
dallas tx
have new icon stage 2 2.5 lift going on 2020 expedition platinum. Trying to figure out how to bypass the active suspension connectors so I can continue to use the drive modes as well as it not trip any warnings. Any suggestions? Was told the ford came out with new firmware that is not allowing people to use suspension bypasses any longer on the new bodies.
2020FordRaptor
Nevada
I would think you could delete it with Forscan. Could be mistaken. Welcome to the forum!
B
Bwiddie
dallas tx
I think the problem is that when you use the new icon shocks you break the circuit from the original active suspension and it triggers a fault. The expeditions prior to 16 I believe allowed for you to hook up the bypass on each strut and it would trick the system into thinking the struts where still connected.
