Advice on Towing 25ft RV with 2021 Ford Expedition Max Limited 2x4 + Transmission Cooler Suggestions
vitaly87
California
Hi all,
I’m thinking about buying an RV (around 25 feet, total weight between 5,000–5,500 lbs). I’ll be towing it with a 2021 Ford Expedition Max Limited 2x4 (non-HD). Do you think this setup is a good match for that weight and size?
I’m also considering adding a transmission cooler to help with towing. Any recommended models or trusted places to install one near Silicon Valley?
Would appreciate any tips, suggestions, or personal experiences. Thanks!
CDNRabbit
Ontario Canada
I like to pick fights with the towing police. I find the expy has no problem operating at it's max stated capacity. My only reservation would be if you're towing at higher altitudes.
It's a little tight and will take some careful packing to make sure you stay under the payload capacity. Pay attention to you're tongue weight.
Other than that, you'll also need a weight distributing hitch and a brake controller.
Nimtz31
Salt Lake City, UT
Search the internet “2021 Ford Expedition Towing Selector” brochure. It will explain everything you need to know. Read it thoroughly. It’s really good info and a great start.
I would look into pulling a factory transmission cooler from a wrecking yard or buy one from Ford parts if you really need one. Be sure to top-off transmission and engine coolant after adding it.
LG_123
Toronto
I’d recommend the tranny cooler for sure. We have HD tow and pull a 30’ travel trailer around 8,000 lbs and transmission is the first thing to start overheating if I absentmindedly race up a hill.
But you have an awesome tow vehicle and shouldn’t have any trouble with a 25’ trailer as long as you have a brake controller and weight distribution hitch.
