Air suspension ride height
Lostpuppydog
I have a 99 EB with 4 point air ride system. When I put it in 4wd the air suspension lifts the vehicle a couple inches all the way around. Is there a way to control the system and make it ride at that height all the time? I work off road, however I don't always need/want to be in 4wd but would like the extra clearance.
ssbroly
Ohio
I'd like to know the same thing. I've been wondering/asking that since I've owned mine, but I've never found an answer. I'm assuming no.
L
Lostpuppydog
If no one knows how to adjust the air suspension ride height..... Does anyone know if there is a conversion kit that will make the vehicle sit at its maximum height? Strutmasters kit only sits at normal ride height which makes the expedition look like a damn grocery getter.
L
Lostpuppydog
I plan on a 3" body lift.... My rig is AWD so suspension lift is not an option, hence why I want to get as much out of the stock suspension as possible.
joe shmoe
Cornelius,Nc
I know there is a ride height adjustment on the rear.It is just above the rear axle, it has a adjustment nut,loosen the nut a carefully push up on it then lock it in place.My 01 EB sagged a bit when I shut it off but I didn't like it I wanted it level.As far as the front goes it has the same ride height sensor but on mine its not adjustable.
L
Lostpuppydog
The front seems to always be a little higher than the rear in general....I'll check it out. Thanks!
