If I check my oil after running the engine a short time it checks almost exactly at the min line, however if it's been sitting a few days and I check it's well above the max line. Does everybody's expedition suck that much oil into the system at startup? What kind of difference do the rest of you notice between the check levels when oil is in the system and when it's had time to thoroughly drain?
Thanks. Mostly I'm just trying to figure out the little traits of the expedition, but I'm also trying to ensure I have the fill level right since at the change I only put in a little less than 5 quarts.
