Expedition Dave
Any 1 - 2 Inch Rear Coil Spacer Lifts? I would prefer the smallest lift possible to use in conjunction with my Bilstein 5100 shocks.
Thank you...
Thank you...
Rough country states the rear spacer gives 2" lift, not 3".I am as high as I can get on my Bilsteins. I am looking at the Rough Country 3-inch lift (coils front and 3 inch spacer in the rear).
I want to keep the Bilsteins in the rear, but If I use the spacer will have to adjust them down so as not to look too butt high or strike the frame .
I would rather just add the smallest spacer available and keep the Bilstreins as high as possible.
How much are you towing? Anything over 600 lbs needs a weight distribution hitch.Thank you, I corrected it. What I need is 3 inches in the rear to keep the factory rake for loads and towing...
