Any 1-2 Inch Rear Coil Spacer Lifts?
sjwhiteley
Kentucky
So, I have the dreaded shock oil leak on one of the rears, and looks like the front. I just purchased the 5100 shocks: can't you bump up the ring on those or are you looking for more than that? (I know you have some posts about it, but can't find the relevant one at the moment).
Expedition Dave
Expedition Dave
A Tiny Little Dot in Florida
I am as high as I can get on my Bilsteins. I am looking at the Rough Country 3-inch lift (coils front and 2-inch spacer in the rear).
I want to keep the Bilsteins in the rear, but If I use the spacer will have to adjust them down so as not to look too butt high or strike the frame .
I would rather just add the smallest spacer available and keep the Bilstreins as high as possible.
1badhabit
Missouri
I am as high as I can get on my Bilsteins. I am looking at the Rough Country 3-inch lift (coils front and 3 inch spacer in the rear).
Rough country states the rear spacer gives 2" lift, not 3".
Expedition Dave
Expedition Dave
There are several reasons I do not want my truck "leveled" and prefer the slightly nose down rake. From aeros, to handling, to towing, to loaded with gear, etc. If your truck is 100% leveled when it is stopped, under accelration and engine load/torque it can actually nose up a bit as well...
I am 2x2 inches now, and want to raise the nose but raise the rear equally as well.
