Any idea what does HD tow package do for 22 timberline?
ThYenAlPyH
Seattle
Hi Folks,
I just ordered 22 Timberline trim with 501A. I was comparing what come with HD Tow package comparing to standard features. It seems that integrated trailer brake controller and pro trailer backup assist are the only two that didn't come with standard feature. Am I miss anything here? Is it a big deal if I decide to tow something? (I rarely tow anything but thinking maybe I can tow a small trailer for road trip)
Thanks!
Chromo
Colorado
You will get the 7 pin harness but I think you are correct about not too much more, and it looks like you loose Active Park Assist 2.0. If you are towing a small trailer for an occasional road trip you will be fine without the HD Tow package, as towing capacity should still be around 6,000 lbs. HD tow package will bump it up to 9,000+ lbs.
StephenPT
Portland, OR
Not sure if the Timberline includes it as part of the base spec, but on other trims the Heavy Duty Tow Pkg. gets you the 2-speed transfer case. 4L can be handy in some applications, especially boat launches.
T
ThYenAlPyH
Seattle
yes, this is standard timberline feature listed: ControlTrac with eLSD (Electronic Limited-slip Differential 3.73) Rear Axle and Two-Speed Transfer Case (4High/4Low) with Neutral Towing Capability. Apart from that, it also comes with Heavy duty engine radiator as standard.
T
ThYenAlPyH
Seattle
Since looks like only integrated trailer brake controller and pro trailer backup assist are the missing options in timberline trim, I was wondering whether timberline has the same towing capacity even without HD tow package?
Brut4ce
Orlando FL
yes, this is standard feature listed: ControlTrac with eLSD (Electronic Limited-slip Differential 3.73) Rear Axle and Two-Speed Transfer Case (4High/4Low) with Neutral Towing Capability. Apart from that, it also comes with Heavy duty engine radiator as standard.
Heavy-Duty Engine Radiator has been removed from the HeavyDuty Trailer Tow Package (536).
T
ThYenAlPyH
Seattle
oh, so this is not something to help increase the tow capacity? Do you know which options in HD tow package that helps to improve the tow capacity?
Rob6805
Why wouldn't you want it? If anything it will help with resale.
BrianM
KS
The HD Tow Package increases the towing capacity substantially. Without it, you can't tow much more than a mid-sized SUV. With the HD package you can tow 9000+. That's the main benefit of the HD package, and I wouldn't order an Expy without it.
rallyhard
Spokane, WA
I think the first part of his question was about removal of the HD radiator from the HD tow package; basically "does the HD radiator help increase the tow capacity or not". If it does help, it's odd that Ford removed it from the HD tow package for 2022, while including it as part of the Timberline package.
The second part was asking if anybody knows what specific changes ARE made to the truck when you add the HD tow package. We know the tow package increases the tow rating Ford provides, but I haven't seen a detailed breakdown of what the mechanical differences are between the rigs with and without it.
apex96
PA
I'm of the opinion that ford is just playing the numbers/money game now. I can find no good information that tells me the rear end casing for the 3.73 gear is thicker/stronger than the 3.31 gear. With the omission of a larger radiator for the 22' models (other than timberline), the only differentiating factor for HD tow is now the fact that it comes with the TBC and PTBA standard. I have never found the PTBA useful and I had the TBC added on later. With the range of gears within the 10-speed transmission, a 3.31 geared expeditions can certainly tow 9,200 pounds (not legally according to ford). The suspensions are unchanged from an HD tow to non-HD tow expeditions (I've looked up the rear suspension components for 2018-2021 models and the springs are the same) from 2018-2021. I doubt there will be any variation in spring rates for the 22's based on the addition of the HD tow package. Most folks will need to add some type of WDH and sway control for their trailers, whether you have HD tow or not, as the HD tow is limited to 6000 lbs without a WDH according to the towing guide (2018-2021).
Ford wants you to pony up the money for the packages. I believe the vehicle is just as capable without HD tow, and parts of the HD tow package can be added on after the purchase by the owner for less.. Yes I do understand the HD tow package can help when it comes time to trade it in or sell it outright.
rd618
new york
Odds are you are spot on with ford essentially making it a “pay for play” option. Check that box, give us 800 and you get to unlock 3000 more lbs of towing.
duneslider
Utah
I would think you would be more likely to experience higher transmission temps towing at 9k with the 3.31's and I would also assume gas mileage when towing that high would be worse.
The brake control can easily be added later.
mrmustang
Greenville, SC
Looked at the Ford parts website this AM, there is a component kit that lists out at $1,7xx that is part of the HD towing package,and while not specifically listed (my understanding is there are 30-35 different parts included in the package that get installed, how big or small is unknown at this time as I cannot find an actual production parts breakdown), I would assume a recurve of the ECU/software for the specific items included in the HD towing package, added cameras, wiring for same, brake controller integration, etc, are the added costs for the package as well.
Bill
rd618
new york
Bill
I wonder how many of these components are helping contribute to the GVWR increase. If the ECU is retuned to kick cooling in sooner for example, that makes sense it would increase ratings, but then I would just question why ford doesn't program that from the start, less software to maintain and better reliability long term.
rd618
new york
Agreed. 3.73 makes a material difference, not to say someone "can't" tow 9k with the 3.31, but why risk the damage.
apex96
PA
Not necessarily; when placed in TH mode the ECU, PCM and TCM will search around to find the right gear to hold the vehicle within a certain power band range. While a vehicle equipped with a 3.73 axle may run in 9th gear, the 3.31 may instead run in 8th gear. The programming isn't going to lug the vehicle and produce unecessary heat in a higher gear if it can downshift to a lower gear, no matter the rear end gear ratio.
Bill
30 to 35 different parts isn't a whole lot. I'd wager 50% of those parts are fasteners or trim pieces of some sort. If for some reason ford did change the ECU/PCM/TCM mapping between the packages I'd be very surprised... If they did modify ECU/PCM programming for the HD tow package, you can pay around 500-1000 for a tuner to reprogram your non HD tow vehicle for even more power and better transmission shifting then what came from the factory, if so desired.
mrmustang
Greenville, SC
Why bother to go through all that, spend additional money on a brake controller (Ford over the counter or otherwise), $500-$1,000 for custom tuning, when the retail price for the Ford HD towing package is only $795.00 Why piecemeal the parts together over the counter, at a cost twice that of the package parts cost alone and no install? The plus side, it's all Ford parts designed to work together for this very reason, and it's installed at the factory so you don't have to. I guess it's a matter of wants and needs, that, and what a few of us here feel is a "better to have it and not need it, than to need it and not have it". If you are ordering an Expedition from the factory and not buying something off the lot, why would you not add it to the 70K plus you are planning to spend for your Timberline.
Bill
apex96
PA
Bill
For many people it may make sense to order the package, for others perhaps not. If I was ordering it sure, add it on, but Ford really has paired down the HD tow and kept the price roughly the same. Folks are getting less for their money...
Forscan can be had for a small fee and the brake controller was about $150 on TASCA last year. Tune was $500 for tuner and program so not terrible.
To be frank, I'm not in agreement with Ford slowly removing things from the HD tow package and making you spend more for them as additional add-ons, when from 2018-2019, I believe they were all included in the package (trans cooler, upgraded radiator, PTBA, TBC, 3.73 rear end, eLSD, 4-pin and 7-pin connector). form 2020 on, Ford as methodically removed pieces that made up the original HD tow package.
I'm also not one to order a vehicle, I do prefer to check dealer lots, and find one in person that best suites my needs.
wakeboarder
Fort Lauderdale, FL
When I looked, it showed different options for the rear springs which included HD tow. Also 3.31 gears will have higher contact pressure at the same pulling force. Also, the 3.31 has a different carrier assembly. I’m not saying that it won’t work. I’m just saying they are different.
