Auto Start, Shift to Park then Restart Engine error
jdmduluth
Duluth, MN
Anyone else have this issue where when at a stop the Auto Start shuts down completly and this warning light pops up requiring you to shift the car into park then hit the start button before being able to advance to shifting into drive. image0 (4).jpeg
Rob6805
Your battery is going bad. Same thing happened to ours. Same message on the cluster. Top tip.. make sure you disable the ASS (auto start stop) after you start the vehicle. ASS kills batteries especially if you short trip a lot.
SunnySunshine
SF Bay Area, CA
Rob6805
From what I have gathered on this forum, the only way to disable it is through Forscan. No? What year and model is this OP?
There are disable devices out there but it's easy to just push the button every time you start it.
LegalBrief
zephyr Cove, NV and SFO
Disable devices are the way to go.. no one knows it’s there but you…
There is also a TSB on the topic
VBreithaupt
To the original question. I bet its the battery. To the rest of you who every start up hit the auto stop button. The autostop eliminator is a must have and it is very easy to install. And look its on sale!!!
Grizguy
Erie pa
I highly recommend to get the auto stop delete. Very easy to install.. no more surprise shut down.. or worse.. surprise start as someone is getting in or out of the car.
PTurbo
Same issue. Dealer replaced battery and still persists. Did anyone find a fix?
LegalBrief
Bad battery… get a auto start stop bypass
Look on this site for links… best $100 I ever spent and is super easy install, never to be thought of again
