Aux Trans Cooler
trdragons44
nj
Just got a new 7X16 foot box trailer to haul whatever i need to. I was wondering where you guys think mounting an aux trans cooler would do the best. Yes i have the hd tow package(with cooler) just looking to cool the trans as its already been rebulit once. :(
nvycrmn
Springville, IA
i would invest in one. i had one on my 98 and that thing never got hot even while offroading in deep mud.
JUST4FUN
Admin
Moderator Administrator
Il
dont over cool the trany.that can be bad too
nvycrmn
Springville, IA
it was mounted behind the bumper where you have that hole in the middle. gets good air flow in there.
thevalleyboy
Calgary
JUST4FUN - what have you heard about over cooling - most of the aftermarket tranny coolers have bypass system that if Temp doesn't go high enough it doesn't use all the cooling - but I've done serious research on my past Astro and basically nobody could tell me optimum Tranny Temp - but with the big cooler in my old Astro I used to run around 150-160F - up here in the north eh... had NO issues - and was told that is ideal - cannot confirm any tranny specialists here?
etrailer
Wentzville, MO
Overcooling a tranny is pretty difficult to do. About the only time it can be a problem is if the fluid is too viscous that it won't flow properly. If it's too thick, the pump can have a hard time moving it.
That being said, usually that has less to do with overcooling and more to do with not having the proper fluid.
With a trailer that size, an aftermarket cooler would definitely be a wise investment. Heat is a transmission's worst enemy. Keep a transmission at an appropriate temperature, the fluid stays healthy, and that leads to the guts lasting longer. Overheating the fluid results in a breakdown and deterioration in the fluid which leads to a rebuild or replace situation.
