Battery hold down bolt
OneLong4x4
Iowa
Anyone know what size the battery hold-down bolt is? Diameter & thread pitch. I busted mine off. Penetrating oil and heat will remove the remaining portion. Then I will be sure to use antiseize and/or get a stainless bolt from Fastenal.
Thanks.
B
bedrck46
Guest
not sure of the size but most likely metric You could drill it out and re-tap it and get a SS bolt from the hardware store
toms89
technical advisor
MD
10 MM, fine thread I believe. don't know what count though.
Bolt head size may be 10mm but pretty sure the bolt is not.
I would check mine against my tap and die set. Easy way for me to identify thread count and size but would have to disconnect battery and remove the battery cover to gain access. Then everything resets.. :(
mkc1962
alabama
What you need is the following
m6x50
A 10mm wrench fits 6mm bolts. 6mm bolts only come in 1 pitch that being 1.00 (some might call that fine thread) the 50 is the length. In order to make it through the hold down block and have enough thread to bite the lower nut with a worthy distance the 50 is the length. The next avail size is 40 which on mine was not long enough.
Personally recommend stainless steel due to the corrosive nature of the environment, and a dab of nickel antisieze never husrts either.
hope this helps.
gnorman
