rob4092xx
Has anyone had to replace your battery yet? Does it need a special battery only offered at the Ford dealership or will a Costco battery fit? How difficult is it to replace the battery? Thanks!
What AGM chargers have people tried with their 4th gen Expy’s? I see several options on Amazon...Thx.
I am confused. What is an AGM battery? Thanks!
I have a Schumacher Charger it works just dandy on AGMs.
Schumacher SC1281 6/12V Fully Automatic Battery Charger and 30/100A Engine Starter with Advanced Diagnostic Testing https://www.amazon.com/dp/B07BLLRM8R/ref=cm_sw_r_cp_api_i_dBbEEbVJF81XZ
X2 Power are some of the best AGM batteries out there with a solid warranty.
https://www.batteriesplus.com/productdetails/battery/car-and-truck/ford/expedition/2019/v6-3.5l-800cca/sli94ragmdp
They are a starting and cycling battery so even if you fully discharge the battery you will have no issues charging it again fully.
I have a 2016 and it looks like our batteries are slightly different. But the link is for the 2019.
Seems the 4th gens are only available in 820 CCAs.
The 15-17s are 930 CCAs
Are the 15-17 batteries AGM? Just a little battery trivia, the X2 Power batteries where an identical clone of an Odyssey. Odyssey’s parent company EnerSyn just bought Northstar out. Not sure they will keep the X2 Power name or not.
I have the NOCO genius 10, older 3500 and 3 of the 1’s. They are the best bang for the buck IMO. I also have the Optima 1200 charger. It’s amazing, but a little more money and way bigger.
Hi-
I just purchased an Optima 1200.
I have a Ford Exp 2019 and the battery is a BAGM 94RH7 800.
When selecting the battery type, do you select the
1. 12V High Performance AGM (engine starting) type or
2. 12v standard flooded/AGM for autos
The high performance ones appear to be for the Optima brand batteries but I was not sure how the standard Ford AGM battery would be classified.
Curious to know what people have used.
Thx.
Bruce
The 1200 is an outstanding charger. It pays for itself every year keeping my old Optima’s running. Yes, the first setting has a special charge curve for the Optima brand battery’s with the dark grey battery case and red or blue top. The fuel gauge is dead on when using with an Optima. But it’s only rated to a max of 100ah. The Standard battery AGM setting can go up to 130ah. So if you have a larger AGM in your boat,RV and Bigger trucks you use this setting. I use this setting for the Expy. Pretty sure it’s not a performance battery.
Thx for the response. I just got off the phone with my local Ford dealership parts manager and he said that given the Expy supports Auto Stop Start, he believes that the AGM battery in the Expy would be considered a performance battery.
I had started charging as a standard but after the call restarted the charging and selected the Performance option.
Any idea what happens if there is a mismatch? Overcharging can occur?
Thx.
How are you running down the battery? It’s only two years old so is this what we can expect? Do you love in the desert?
