Battery Tray Removal?
guitarjesus
Crestline, CA
Replacing heater hoses, would be way easier for my hands if the battery tray is out of the way. Is there a bolt or clip on the bottom side? I have all four bolts removed up top and it doesn't want to come out.
Trainmaster
Old School Member
Rockaway Beach, NY
According to the shop manual, There's a screw in the bottom and a pushpin toward the windshield cleaner bottle. Then remove the four bolts, two on bottom and two toward the bottle. The harness along the edge is snapped on in two places
I just removed mine to route some wires. My 2023 did not have the screw in the bottom. Otherwise, I took everything off and pulled the tray up, wiggled it out between the wires. There's nothing else holding it in at all.
You might put some anti-seize on the bolts when you put it back; these things rust solid over the years.
G
guitarjesus
Crestline, CA
It definitely has a screw in the bottom. I pulled HARD and it wiggled but wouldn't pull up. Thank you.
I'm replacing the inner heater hose. I know people say to just cut them. But do you know the Ford or after market tool number for releasing the clips on the hoses? Thanks.
G
guitarjesus
Crestline, CA
The screw should be visible right under the battery in a bottom depression toward the rear of the tray.
Found it. Tiny looks like T15 screw. There was coolant in that dip in the tray from when the hose junction blew up. I soaked the coolant up, found it. Thank you
