Big Brake Kit
Lynnii2
Navy
San Diego, CA
Hello,
I was wondering if anyone knew if I could use the Brembo 6 Piston Caliper from a 2010-2017 Range Rover Sport or Mustang 2015 and up and if it would fit on a 2010 Ford Expedition. I was able to find the bracket part number for Wilwood, StopTech and brembo. I can find used bbk on ebay and local salvage and wrecking yards. I wanted to save some money and get a used calipers and just buy stop tech rotors and stainless steel lines and call it a day.
Newport News, VA
you'll need to check the back spacing of the caliper...i called brembo years ago and they said they can get me what i need so call them to see if the measurements line up
Lynnii2
Lynnii2
Navy
San Diego, CA
Here is the other post I did.
https://www.expeditionforum.com/threads/big-brake-kit.44839/
I called Brembo and the said they don't know if calipers from Range Rover Sport, GT350, GT500 caliper will line up and they are 16'' caliper and will use rotor from 15''-16''. I don't know why it is so difficult to do a swap on these Ford F150/Expeditions. The damn F150 is the most popular truck out here hands down, but yet know can do a sway like you can with all the Chevy, GMC and Cadillac trucks. I have friends that have use Corvette Brembo, Cadillac ATS Brembo swaps on Toyota FRS, Honda, Acura and etc.... I can find Brembo 6 piston calipers from Shelby GT350, GT500 and Mustang GT. I want to make a cheap kit if possible for under a $1000. I want to make a cheap kit if possible for under a $1000. I don't want to spend over $2000 which I find to be over priced to do a front BBK.
I did find some information that said you could possible use StopTech or Wilwood caliper mounting brackets can be used with Brembo calipers. I did call Baer and they charge $85.00 per side for caliper mounting brackets , Alcon brackets ar $220.00 per side, but the problem is if it doesn't line up I spent money I can't get back. I wish I could buy it all and see if it fits and return it if it doesn't not. I know this company https://ctsvbrakeswap.com/ makes bracket for Chevy, Nissan, Subaru and a few other and they all use Brembo calipers. I will call and see if they have some brackets in the works. I guess as a last resort I could have some CNC made by a local shop and see what the cost might be.
Lynnii2
Lynnii2
Navy
San Diego, CA
I found some 2017 Mustang GT350 6 piston Brembo for $500, I would still need to buy 6 lug brake rotors, pads, caliper brackets.
