Spiffyrides
Hi All,
having an issue with my front blower motor on my 2016 expo EL, 3.5 ecoboost, 4wd with climate control. I looked at other blower threads but none seemed quite like this issue.
Issue began where the front did not seem to be blowing with much intensity, blowing, just a very small amount. Blower motor was making some noise as it if had a very large amount of load on it, an electric motor him or buzz sound is the best I can describe it.
Upon researching forum posts, some reported issues with the blower motor resistor or with debris in the blower cage. I’ve replaced the resistor with no change and didn’t find anything in the blower when I removed it.
The part that is odd to me is if I remove the blower from the air box and run it, it blows fine, speeds change, it will go up to high power etc. if I install it in the airbox, it will not. I’ve even installed the blower without the screws and held it in place. When I do this, if I lower the blower a small amount, it will work, but will “load up” and slow down if I put it all the way in. On a visual inspection, I don’t see any place it’s hitting or rubbing anything.
hoping that someone here may have some ideas on this.
Thanks in advance,
Frank
Thanks in advance,
Frank
