Bluetooth Transmitter
Dbotts
Susq,PA
I am looking for a blue tooth transmitter that I can plug into a 3.5mm analog audio output on a HAM radio set, that will pair with the Ford SYNC system in my 2018 Expedition. ---- I don't want an FM transmitter. ---- I want the audio from my HAM radio set to go to a blue tooth transmitter, that will pair with the ford SYNC radio capability. Looking for a Blue tooth transmitter like the one I use when I fly commercial, to listen to the aircraft entertainment system with my blue tooth headset.
I have not found a Bluetooth portable transmitter that is compatible with the Ford SYNC Blue Tooth capability.
Has anyone has used a 3.5mm audio source with a Bluetooth transmitter to connect to successfully to SYNC 3 capability ???????
Or is there another way to get this 3.5 analog audio into the SYNC audio system other than an FM transmitter.
I apologize for the redundancy, I am just trying to be clear and get to a solution for my need.
Thanks in advance.
