brake booster advice
blaunerb
Indiana
2005 Navigator. I have a vacuum leak on the seal in the cabin on the brake booster so I am going replace the booster. apparently there is two boosters 1) for vehicles with stability control or 2) without stability control AND a big price difference (almost 2x). I replaced the air ride shocks with coil overspring. Can I use a brake booster that is to be used without stability control? Thank you in advance for any advice!
01yellerCobra
San Diego
The stability control is in the computer. And I believe it controls the brakes to bring things under control. So you'll have to use the correct booster.
Newport News, VA
if you dont have it dont use the one for stability...also..check the master cylinder as well...
