Brake Hose
Plati
First find out the problem. Then google it.
Unless you have the tools and know how to do it … hire a shop!
I paid $500 to have my 2 rear lines replaced on the 2003
TobyU
Ohio
Easiest is to remove both ends so you can match up style and threads....then go get you on at least long enough at parts store. You can bend a wave or loop in it to take up any extra slack. Then hook to supply end first and tighten up then make sure master cyl is full and leave other end unhooked.. have someone push pedal to floor then put thumb on end of line as they let pedal up....they push..you let thumb off....then cover as they let up...Bleed the ton of air that will be in new line this way and when you get only fluid (don't get it into eyes or on paint) connect that end.
You might have to bleed all the wheels if it the master cyl ran out of fluid at any time.
Right rear, left rear, right front,left front is order.
Harder way is to get line and cut to exact length and slide fitting ON FIRST then bubble flare the end.
Sometimes a line has two different threaded end so so you have to flare...cause I ain't buying no special expensive lines even if they are available.
tibwd
NH
The line that is affixed to the front crossmember is the passenger front brake line. If it has not been replaced before, it is a home run from abs module to the front fenderwell, where it attaches to the final short rubber/metal length that goes to caliper Least expensive and permanent fix is to replace the line with the nickel copper line, in 3/16 size. Flaring the infamous double bubble can be problematic, but if you are good at normal double flares, you can work around that using purchased double bubble short pieces and using them at the termination points -abs module, final rubber hose fitting- and use your regular flares with connectors to those short pieces. The nickel copper line is flexible and will last forever. The other lines should be checked also. From the ABS module, there is one short line to the driver front, then another homerun along driver side frame rail to the back, where it splits to the driver side rear, and the last line goes from that split,. across the axle to the pass side rear. replacement of the lines can be done DIY, as long as you can flare the line. There are tons of tools out there. You can also buy pre made lengths , though they are costly, and not that easy to snake into place. Lots of folks merely cut out rusted lengths and replace, presuming remaining line is aok. At least in the northeast, the lines rust right after the ABS module and down in the front. I think it is safe to say any 2nd gen XPS that reside in places that have snowy winters either already have new lines, or need them. They are easy to inspect. Start at the abs module. good luck, Tom
Junker
