Hi all. I have a 2022 Ford Expedition Max. Intermittently, the brakes will prevent our vehicle from backing out of the driveway. Usually, it will not move at all unless the gas is pressed hard. Occasionally, it will stop after we back up a small distance, and then you have to press the gas hard to get it to continue backing up. Our driveway is about a 5% grade. It mostly does this when the weather is cold in the winter. We always use the electric parking brake when parking, and we always disengage it when backing up. The dash indicates it was disengaged. I know this sounds like reverse brake assist, but the vehicle gives no indication that reverse brake assist is being activated when this happens. There are no alert tones and no dash messages appear when this happens. It will also do this with reverse brake assist toggled off in Sync, but it does seem to do it less often. Has anyone else had this happen? What was the issue?
