Brakes Squeak When Driving Slow
ajpjeep
I have a 2007 Ford Expedition EL 4WD which has been in and out of the local brake shop for the last few weeks (they're stumped). Calipers, rotars, brake lines, and pads have all been changed (twice). ABS checked out fine too. For some reason, my pads and rotars seem to be slightly touching all the time. When I roll through a parking lot (without pushing the brakes) they go, squeak, squeak, squeak.
Here is a video I took rolling through the parking lot:
https://youtu.be/6q94SAQECXc
Any ideas of what I should check next to get this fixed?
Aaron
JUST4FUN
Admin
Moderator Administrator
Il
They make a spray that you can put on the back of the pad i think its made by Permatex
stamp11127
Temple, Georgia
Does it stop when you you apply the brakes lightly? If it doesn't check for bent backing plates.
A
ajpjeep
Yes, it does stop when I apply the breaks slightly. It seems the brakes are rubbing even when the pedal is not applied.
JUST4FUN
Admin
Il
that's the stuff that I used to use on the squad cars when they had squeel problems made by Permatex its purple.I would spray it on and let it tack up then reassemble this should solve your squeal problems
