Broken Dip Stick tube
Will Williams
South Boston VA
I was checking my oil today, and when I pulled the dip stick out part of the tube came with it. I was wondering if anyone had seen this before. And how they fix it.
99WhiteC5Coupe
You may want to list your year, make and model - with engine designation, to receive specific information.
Most engines have the oil dipstick tube pressed into the engine, with an o-ring attached. Some also have a tab on the tube, which use used to support the tube with a bolt or screw.
tolken4
Saint louis
Yes, relatively common. Hard to get out but best bet is a small pry tool and hammer from underneath. It will go back without removing headers, but it’s a bit of work and you need to push it for again the underneath to get it to go in the hole.
Hamfisted
Ft Lauderdale
There's a retaining bolt that secures it to the side of the head, but the lower end of the tube is just hand pressed into the side of the block and fairly easy to remove. If it's already broken you can just remove the bolt ( 17mm ?) and pull the rest out with Visegrips or something. A new tube is about $40 on Amazon.
Ford 5.4 Oil Level Tube on Amazon
Complete oil level tube.... Oil Tube Motor End with O-Ring seal ....
