Dib52
Hey Toyman... Does your look like this? Mine is the Stone Green Metallic.
Toyman, did you set the positions per the manual ( page 176 ) first ?
You want the key in the ignition or vehicle running in Park to properly set things. Basically you adjust the seat, pedals, and mirrors to the way you want them then press "SET" then press "1". Now go adjust the mirrors or seat to a different position and then press "1" again and see if they go back to where you had them.
If the seat automatically moves forward when you put the key in the ignition then you have the "Easy Entry" mode set.
Matt
I'll do that tomorrow. Didn't I read somewhere in the manual that you can also program the settings such that it can activate the memory function based on the fob used to unlock the doors.
I'll re-read that whole section later as well.
