kgreenjinx
Let me start by saying I am confused. I have searched the forum and numerous vendors sites, but can't figure out exactly what each kit takes care of. Pretty much only can find part numbers. In searching forums I found part numbers for Moog camber kits of K8740 ($16.11 ea.) for the front bolts and K80064 ($35.79 ea.) for the back bolts. I put a 3.5/2.5 leveling kit on my expy and it is now time for new bigger shoes and I also did the air ride to coilover conversion.
To clear up any confusion and discrepancies of what I was reading, I assume I need two of each of the kits to complete the front end. Correct? What about the back end? Will I also need to order some for those (different part # ?) or does it have adjustment in the rear. My total is coming to over a $100 for both front tires. I am assuming I need to have them installed on both the upper and lower arms?
I will be taking my bolts to the alignment shop and letting them put them in. I just want to have everything I need to do it. I looked under my expy and it is still the factory cam bolts. My current tires are really wearing on the outside. At least in the front they are.
Thanks for any guidance you can give and forgive my ignorance. i just don't want to order more than I need to since I am on a budget with buying tires as well.
