03 Intake advice
03trk
seattle
I am looking for some advice, My new to me 03 expedition 5.4 came with the coolant leak at the passenger side front of the manifold, I got everything to reseal it and started the job yesterday and was extremely disappointed to find out someone had installed a Dorman manifold already. So my question is should I stop before I get any further and try and find a good ford manifold or should I just continue forward and reseal the Dorman unit? I stopped before I got to far in to it so it’s not a lot of work to reassemble at this point. 179,000 miles on the truck no ideas on the manifold.
Appreciate any input.
Yupster Dog
Moderator
Unless you want to do it again, get a OEM manifold.
Many post on here about getting aftermarket manifold, and they all had to do it again with a OEM intake manifold.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
At that age & mileage, there would be 2 main questions I would have to answer before proceeding:
A) Am I planning on keeping this beast running for a good while longer, AND:
B) Can I find an OEM manifold in a junk yard somewhere close by for a reasonable price ?
If the answer to A is yes, then I would invest in a genuine ford manifold, either new (if you can even find one) or from B....
If the answer to A is NO, then I would stick with what you have & just seal it up as best as you can, and get whatever miles are left in it.....
I know that in '24 I had the right side manifold replaced on my '011 with an OEM part and it cost me about $1350...some of which was because the shop had to torch/cut/grind off the original bolts & studs, tap & drill the new holes, then attach the new parts... so lots of labor involved !
Good luck with whatever you decide :D
03trk
seattle
Thank you, I definitely want to keep it ! I have done a lot of reading. I guess I will probably reassemble and start looking for a manifold .
03trk
seattle
I have ordered the correct Manifold, could someone be so kind as to let me know what size and length bolts I need to get? I can’t reuse what is currently on the manifold as it’s a Dorman and I would like to have the bolts ready to go when the manifold arrives.
Thank you
whtbronco
Winchester, VA
I was hoping to have replaced my intake over either of the last 2 weekends. Unfortunately that was not to be and it looks like my next opportunity will be in June. Sorry to say I can't help with the bolt info right now.
03trk
seattle
Thanks everyone, I was able to go harvest most of the bolts at pull a part.
Just about have the old manifold out. Running out of time for today
