I towed my BMW M3 on a U-Haul trailer. No air ride. Probably close to 5500 lbs. Towed like a dream. 70 mph+
Which M3?
Which M3?
Put car trailer on truck with rear air suspension and did not handle well. Vehicle on trailer was a S10 for a project for older truck. Any suggestions, maybe have to use load leveling hitch which i did not need with my e250.
Where did you get these?does this count ?
they say they weigh 250 each, well i have moved them around the yard and cut them into quarters and i bet is 350 per tie. they are composite ( high tech plastic stuff)
18 on board. 6300 lbs of load, trailer is 1800 empty.
it drove just fine
a friend that works for a company that refurbishes rail road lines, these were put in for commuter trains and failed quickly so the company pulled them and replaced with wood ties, the problem was the spikes split the plastic, instead of drilling first .Where did you get these?
Not to dig, but you did something wrong. The Expeditions tow great. I tow a 24' enclosed trailer. The only time I have trouble is if I don't put enough air in my tires or if I load the car wrong. Too far forward or worse, too far back.Put car trailer on truck with rear air suspension and did not handle well. Vehicle on trailer was a S10 for a project for older truck. Any suggestions, maybe have to use load leveling hitch which i did not need with my e250.
20131008_120244 by Dave H, on Flickr
I do. An 07 Eddie Bauer and a 17 Platinum.HawkX66 do you have two expys?
