in two months?I still put one on mine... In about 2 months I will open it up and report how much junk is in it.
in two months?
I empty my can twice between 7500 mile changes. Wouldn’t hurt to open it up and lookSorry, I should have clarified... in 2 months or so when I change my oil I will empty it and see whats in the can.
I've heard the the new gen engines on these trucks don't need a catch can.Do you need a catch can on the 2018+?
Thanks.
This^^I've heard the the new gen engines on these trucks don't need a catch can.
2-3oz after 5K is nothing. The engine has a PCV, that burns most of this stuff. Does the the catch can, prevent this? Old timers used to say, too much 'blow by', meant bad rings or valves. The intake valve 'carbon issue' is not fixed this way. The valves still are not washed by the fuel. Ford admitted, there is no way to prevent it or safely clean them. They re-designed the entire fuel system. In cold weather, engines get pudding under the oil cap(and valve cover). It burns off after a long drive or the first warm day. What does a catch can do for that?I would put one in regardless of year. You don't want that oil coating the inside of your intake.
I have one in my 2013 Mustang GT with 5.0L engine. I remove about 2-3 ounces of oil every 5k oil change.
Opening this thread up again to see if anyone has feedback on catch cans for the 2018+ Expy's. Good? Bad? Needed? Thanks in advance.
