CEL 1450 and possible cause?
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
Bonnie threw a P1450 code and I'm wanting to figure it out. I did look around under the truck while she was on a lift getting an alignment and found a disconnected hose that is in the picture.
Does anyone know what it's supposed to connect to? I didn't find anywhere it could connect to so if someone could crawl under their 2003 or 2nd Gen and let me know I'd appreciate it.
Hamfisted
Ft Lauderdale
Doesn't connect to anything on that end. It's usually just tie-wrapped to one of the other pipes there. It's just a vent hose for the fuel evap system. Don't plug it. When you remove your gas cap after driving do you hear a big hiss or the sound of pressure being relieved ? Check the condition of the vacuum hose from the motor over to the evap purge control valve there by the master cylinder, it rots out after about 10 years. If that looks bad change it out. Then it might be the control valve itself gone bad. Those are the common causes.
https://www.amazon.com/gp/product/B0042HHE4M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
https://www.rockauto.com/en/catalog...on,vapor+canister+purge+valve+/+solenoid,4936
CertusExpo
CertusExpo
Fort Worth, TX
No hiss in least but I do have an oversized tire stuffed up into the spare tire cavity. Is there something there that could be kinked?
Hamfisted
Ft Lauderdale
Yeah there's a few hoses back there but a tire shouldn't hit them. If this is a new code and that tire has been there for a long time, it's probably not the issue. But if you just stuffed that tire up there last week, and now you have this code, it would be worth a look.
Habbibie
Is it Christmas yet?
Chicago
This is off of my 05, looks to be a much bigger in diameter breather hose on mine.
You're looks like it has a clip that connects it to this little cutout
CertusExpo
CertusExpo
Fort Worth, TX
I thought the same however, the diameter of the hole is smaller than the clip with four little prongs as well as being just shy of long enough or angled correctly.
This is why I felt that there was something missing from there that was an intermediary connector.
Edit: mine also had the zip ties which I cut off to search for where that 'connector' went to. That 'connector' seems like it belongs somewhere although yours doesn't seem to have it.
Even more confusing...
Habbibie
Chicago
Ok is your little skinny hose going to the same place as mine is?
CertusExpo
CertusExpo
Fort Worth, TX
I'm going to need to take a second look on mine and compare to your pictures.
Thank you for those.
1,381 to go.
lincoln
TX
P1450. Tough one to figure out. Could be Canister Vent Solenoid, Vapor Management Valve, Fuel Tank Pressure Sensor, charcoal canister, evap hoses, or wiring. Or a combo of those things. If you fill gas and it stops before tank being full it could be blocked hoses or defective Canister Vent Solenoid (above spare tire next on the charcoal canister). I replaced mine and it fills all the way now but still had the P1450 code. I replaced Vapor Management Valve (in engine compartment drivers side firewall). Only thing left on my list to clean, test, or replace was the FTP sensor. That was a pain to replace as it was on top of fuel tank next to fuel pump. Involved dropping tank and splicing new short fuel lines (5/8"? fuel hose with twist clamps and hose connectors) to connect to new sensor and connecting the harness. FTP sensor alone on ebay was $30 otherwise dealer part with all the hoses and connections for $350(?). Dealer wanted $1700 just to drop tank, throw parts at it, and investigate more. I dropped the tank and replaced FTP sensor with misc hose parts. That got rid of the P1450 code.
2005 Navigator
CertusExpo
CertusExpo
Fort Worth, TX
Thank you.
It fills all the way without issues and last week, one even kept filling past full and spilled fuel on the ground.
I may replace the solenoid at the firewall for laughs and giggles to see if that affects any positive changes.
