JuniorExp03EB
I just replaced O2 Sensore bank 1 sensor 1. and i think it affected my cats. how do i diagnose that? heat gun?
Sent from my SM-N960U using Tapatalk
Aside from being illegal per federal regulations, now your driver's side has more exhaust back-pressure than your passenger side. A converter is not very restrictive, but it is more restrictive than a straight pipe. And if one side was really "falling apart", then the other can't be far behind. Since the two engine banks now "breathe" differently, the correct fuel mixture and ignition timing for each bank will be slightly different. The best the ECM can do is "average", which means that neither side will be exactly correct. Removing the driver's side converter (not advised) would equalize the pressures. The ECM may, or may not be able to compensate. Correct back-pressure is part of an engine's overall design. I am guessing that Minnesota doesn't have annual vehicle inspections? A mechanic or muffler shop would face a large fine for removing a converter.my pass side upper was falling apart inside. I cut it out and put in a piece of flexy pipe. It was a $7.00 fix.![]()
