Prince_Polaris
Okay, so I think I've talked about it before, but for a recap, my Expy's had some weird performance problems. For example, my MPG doesn't ever hit 10, and it seems like it's gonna dip underneath 9 sometime soon. Also, it seems... weak.
For example, last year I went to morgantown for something, and every time we went uphill, it would lose so much speed that cruise control would give up- and I keep it set to the speed limit, 70!
However, the most recent time I went there, it was totally fine, and only one hill gave me problems at all- I slowed down to 65 while climbing it. Still better than the first trip.
And both trips are on the exact same route, too. And on the second trip, I had a heavy suitcase packed too! Anyway, in addition to this, I've had two different instances of the engine shaking at low idle. First time, the check engine light was flashing, but giving it a rest and restarting it fixed both problems. Second time, it flashed again, restarting did nothing, and the light stayed on.
So since it actually kept the code this time, off to autozone I went, and I got those three codes. Misfire on startup [first 1000 revs], cylinder 2 misfire, and system too lean.
What I want to know is, when I take the poor girl to the mechanic, what should I be telling them, if anything? And alternatively, is it even safe to drive? For some reason, the shaking seems to be an "either it happens or not" situation but I don't want to just drive around if I'm hurting it.
And, my MPG is dropping, before it started these weird fits, it would hover around 9.4, now it's down to 9.2 and I guess it's gonna keep dropping.
A while ago, I got the spark plugs and the vacuum lines fixed, which helped some of my performance and mileage, but ever since I bought the car I've never been able to get to 10mpg! Something's wrong...
