Fordgirl01
I posted in my original thread below but it’s an older post so I thought I’d start a new thread for this question.
I’m attempting to do a compression test but I’m not sure what I need to do to disable the vehicle from starting. I first found the ignition fuse and removed it. The vehicle started so I immediately shut it off. I looked at the fuse diagram again and watched some YouTube videos. I found there is a second ignition fuse so I pulled that. The videos said to remove fuel pump fuse, so I did. Now with both ignition fuses (111 and 113 I think) and the fuel pump fuse removed, it won’t even turn over.
Do I put the ignition fuses back in and just leave the fuel pump fuse out?
Persistent #8 misfire, 01 Navigator
https://r.tapatalk.com/shareLink?sh...-#8-misfire,-01-Navigator.38944/&share_type=t
