asharris1984
So, my husband and I bought a 200 Expedition Eddie Bauer 4x4. Really hating it right now. Our newest issue is that we were towing a boat and the engine started to overheat. We filled it with coolant/water, assuming it was low and had someone replace the thermostat, because we suspected that was an issue. It ran fine for a couple miles and then it started to get hot. It never actually got in the red, but it lingered at the top. Thinking it might be the overdrive, my husband turned it off. The pressure went back to normal for awhile, but then it started to climb back up and idle a little bit before the red. It didn't start this issue until we started towing the boat. We're baffled as to what the issue might be. Is it the water pump is out or just the fact that our vehicle isn't meant to pull that kind of weight. Any help is appreciated.
