Crazy starting isuues
AWD EXPY
Piqua, oHIo
It seems like 19 out of 20 times it starts perfect. Then the moment that it takes 10 minutes to fire up. The starter & battery are doing fine to crank. I just don't know if the injectors or plugs are not firing.
One weird thing is that the odometer kind of resets to the trip meter, with 0 miles. I'm not sure if the PATS or computer module is messing with anything.
Then eventually it will fire up as though no issues are happening. Does anyone have ideas for dealing with this issue?
Temple, Georgia
I'd be inclined to check all the electrical connections to the dash and pats before really jumping into this.
Next time it doesn't start firmly smack the dash and give it a shot at starting.
Lightnig
Behind you
Not quite sure I understand what the actual issue is when it fails to start...
turn the key, and nothing?
turn the key, engine turns over but does not fire?
turn the key, engine starts then quits right away?
A
AWD EXPY
Piqua, oHIo
turn the key, engine turns over but does not fire? That's the one.
IrnBru
East Tennessee
Kind of weird, mine started doing something similar today. Ran fine 15 minutes before it happened. Try to start and no fire. Cranks just fine, it did start one time and idled fine until I gave it some throttle then it start missing and died. Then it wouldn't restart. I'm thinking fuel pump but who knows?
Temple, Georgia
In today's world, that is why every tool box needs a scanner, a dvm and at least a fuel pressure gauge. Now if you have money to burn a good scope would be king.
A
AWD EXPY
Piqua, oHIo
As of today, after an hour and a half of trying, and all I got was a 2 second fire of about 2 cylinders. I depressed the valve on the fuel rail, expecting a spray of gas, but got nothing. I'll put yet another new filter in.
Temple, Georgia
Don't waste your time and money on fuel filters just yet. Get a fuel pressure gauge and see what the pressure is when you first turn it to the on position.
If your not getting the correct pressure it won't run.
This is what we use at work on the lift pumps (fuel pump) for the buses:
http://www.tooltopia.com/actron-cp7838.aspx
A
AWD EXPY
Piqua, oHIo
The bottom half of my truck is rust. Could be a crapload of sediment in the tank...I don't know. Had the same issue earlier this year, with a code. I had replaced the filter, and got good results for about 5 months.
In the self diagnostic mode, no dtc codes are shown. If I hook a fuel pressure gage up and no pressure is shown, could that still be because of a clogged filter? I'm hoping not a pump.
Temple, Georgia
No fuel pressure can be the result of a fuel pump not working. That can be caused by a pump failure, electrical failure or clogged filters. Usually it is pump or electrical failure.
Clogged filters are usually not an issue unless your in an environment that will allow contamination to enter the tank. The other scenario would be a jealous spouse getting even.
A
AWD EXPY
Piqua, oHIo
I reckon I can disconnect the fuel line into the filter, then key on to see if gas shoots out. Then look for voltage and ground on some wiring at the pump. I hope it's not shot. Would it normally make at least a faint noise when first turning on the key?
Temple, Georgia
On the escorts I have you can hear the pump, not from the inside on my expy though. Someone at the fuel fill tube may be able to if their ear is close to the opening.
